22" WS w/ HDMI $339
Daarken
339.99 before $20 rebate @ the egg
http://www.newegg.com/Product/Product.asp?Item=N82E16824112005
Overview
"Attention gamers – need a huge, fast and bright monitor at a fraction of the cost? The Sceptre x22wg-Gamer LCD Monitor is your ticket to widescreen gaming nirvana. Enjoy smooth video and speedy gameplay with a 5ms response time that keeps blurring at bay. Enjoy bright, vibrant images with 1680 x 1050 pixels of WSXGA+ resolution, 300 candelas of searing brightness and a simply incredible 1200:1 contrast ratio. That's enough desktop space for true HD gaming and enough real estate to line up almost 2 full-sized documents when you're finished with your study break. Built-in USB 2.0 ports and jacks for headphones and microphone allow fast connectivity to peripherals and gaming headsets without having to crawl under your desk.
Feel like watching HD movies instead? Sceptre loaded up this beast with VGA, DVI and HDMI ports to fit with most home theater setups. A 170° horizontal and 160° vertical viewing angle, combined with tilt adjustment and VESA wall mounting compliance, gives you flexibility to view your HD movies on this king-sized screen from almost anywhere in the room. Built-in speakers round out this brilliant buy for the savvy gamer."
Read the reviews
Wow thats not bad. HDMI... hmmmmm. Maybe my wife could use this.
It says the maximum resolution is 1680x1050 but also claims to do 1080i/p
Am I missing something?
looks like a good deal on that size monitor...
the 20.1 naga III pva panel fits my budget better though... i'm probably going to pick one of those up when i catch a smokin rebate...
nice 22 though
mal
At 1080p? You're missing about 30 lines worth of vertical resolution, which amounts to... nothing really noticable. That's only about 3% of the screen cut off -- about a quarter of an inch on a screen that size.
I was just reading a post last night about someone who bought this monitor and hated it. Just a warning.
regarding 1080p , it is likely doing the same thing that my 22" Westy does by scaling the 1080 image down slightly. Still looks beautiful and no noticeable distortion - i have my xbox360 hooked up through the components for 1080i.
That can be said about any product ever made.
"You can make all of the people happy half of the time, or you can make half of the people happy all of the time, but you can NEVER make ALL of the people happy ALL of the time." -ancient chinese wisdom :p
[T5K]thrasher;1030535889 said:
Its a little more than just that at 1920 × 1080 :p
D'oh. Ok, so this won't give a "true" 1080p picture, but what it displays will be significantly better than 720p.
Not to threadcrap, but Costco has this monitor cheaper, plus has a $30 MIR:
http://www.costco.com/Browse/Product.aspx?Prodid=11169064&search=Sceptre%20x22wg&Sp=S&Mo=0&cm_re=1-_-Top_Left_Nav-_-Top_search&Nr=P_CatalogName:BC&Ns=P_Price|1||P_SignDesc1&N=0&whse=BC&Dx=mode+matchallpartial&Ntk=All&Dr=P_CatalogName:BC&Ne=4000000&D=Sceptre%20x22wg&Ntt=Sceptre%20x22wg&No=0&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
I mention this mostly because I've heard the warranty through costco is better then the Egg (take it back to a local Costco and get your money back if not happy with the monitor). If you don't have a Costco membership, I think you have to pay 5% more though...
Awesome: Now it's back to a HOT deal!!!
Thanks.. I just hope they keep the deal around after I get my W2... :)
Why the HDMI spooge-fest?
DVI is 100% hardware compatible with HDMI. Buy a cable with DVI on one end and HDMI on the other end if you want to hook some fancy HDMI component up to an LCD.
There's nothing hot about this deal. It's a mediocre monitor for a mediocre price. There are other, better 22" LCDs with the same resolution for cheaper.
More importantly, this monitor (unlike most other 22" panels) has HDCP support. Which, sadly, makes it more future proof, since content providers want to encrypt their precious signals. With HDCP, you (hopefully) won't have to replace your monitor to play full-res HD movies a few years from now.
HDMI, HDCP, 1200:1 contrast, Vesa standardized
like the previous poster (Future Proof)
Exactly what cheaper monitors do you consider better?
For the record... CHIMEI _is_ Westinghouse. THey hbought the brand name Westinghouse, figuring it would go over better in the US than CHIMEI :D
Personally I dont care, the Westy panels are excellent.
Umm... DVI can't carry audo signals... this means HDMI will have less cables. HDMI is easier to connect (no need to screw it down).
Oh, and HDMI is the future of all monitor/video card connections. Next generation video cards (some are out already) feature HDMI connections.
You can also watch HD-DVD movies on this monitor because it is HDCP compliant, via the Xbox 360 HD-DVD ($180-$200) player hooked up to your PC.
Priced just DROPPED another $20. Making this $299.99 AR from newegg. If only I had waited TWO more days before buying it.
