22" lcd mount but using it for 24" lcd? will it work?
if it bolts up it should be ok, unless you use a lot of tilt and the stand base is small. A 24" is pretty close in weight to a 22".
Are you talking about a neoflex? If so, it fits fine. I heard it can support much more weight than advertised.
I went to do it and noticed a sticker that said up to 26" tv and 30 pounds max so ya it worked great tho tightening the tilt screw was a bit harder now I have to buy a 26" lcd
