22, 20" Display Help
XSNiper
Ok, I tried researching monitors for a couple days now and I really haven't gotten very much farther in my knowledge then before, so I need help. Theres just way too many models that have the exact same specs to make a good decision without seeing the product firsthand...
I'll mainly be using this monitor for gaming and a bit of photoshop work. The colors don't need to be perfect but they should at least be close. I'm looking to spend $229 or less for a 22 or 20", prefer 22. I also would like to have one that scales down properly so when I choose a lower then native rez it puts up black bars instead of stretching and blurring the picture..
Any suggestions?
One that really caught my eyes was this one : http://www.newegg.com/Product/Product.aspx?Item=N82E16824009157
Unfortunately I can't find any reviews other then that one there. I'm also concerned with it having a 16:9 rez, will that be a problem in games? I don't want to get a monitor that isn't supported by half the games out.
I looked at that, unfortunately I can't find them being sold anywhere...
