- Jul 29, 2004
So my quest to find the "perfect" 21:9 display has been interesting. I thought I'd share a few thoughts for anyone else that might be interested in these.
A little background - I've had numerous 120hz/144hz monitors dating back to the original Samsung 2233RZ. 120hz is an absolute game changer if you're an FPS player, but I've never been able to get past the color issues of TN. I've also had a surround setup but scrapped it because it's such a huge space requirement on my desk. So when these 21:9 displays first debuted I was very interested in them as a nice "compromise" between a single display and eyefinity/surround.
I've since tried a few and I've jotted down my thoughts below.
LG 29EA73
Pros
Cons
AOC Q2963PM
Pros
Cons
ASUS PB298Q
Pros
Cons
So for me the ASUS PB298Q is by far the best of the bunch, though right now I'm debating on whether or not I want to exchange it. As everyone knows, the biggest risk is that next time I get one with terrible backlighting or dead pixels. But the yellow is pretty annoying and doesn't really belong on a $500 display IMO.
So in the end I have to say that I'm a huge fan of the format. To me it really is a nice compromise without taking up so much room on my desk. It also seems that these newer IPS panels are on par with any 60hz TN panel in terms of responsiveness. No, it is not as smooth as a 120hz display but games have never looked better thanks to the amazing colors. I'll be sticking with it until the 34" versions start coming out (or if there's something mind blowing shown at CES next week
As far as system performance goes, I ran FRAPS while playing BF4 on a 64 man server. Framerates were pretty much pegged in the 70s with my system. BF4 was set to the Ultra preset. System specs:
i5 2500K @ 4.4
8GB RAM (DDR3 1600)
R9 290
256GB Samsung 840 SSD
LG 29EA73
Pros
- Even backlighting
- No input lag
- No noticeable ghosting
- No dead pixels
- Can OC to 75hz
Cons
- PWM backlighting (ended up returning it because of this)
- OSD was fairly intuitive but the touch sensitive controls were a pain to use - overly sensitive so I kept selecting things by accident
AOC Q2963PM
Pros
- No PWM
- Backlighting was fine
- Can OC to 75hz
- OSD was pretty easy to use and it has physical buttons on the side of the display. The power light is also on the side which makes it a bit less noticeable.
Cons
- Noticeable input lag (there may be different revisions of this display, but the one I got was horrible (I ordered from Newegg))
- Two dead pixels in the upper right corner
- There seemed to be some ghosting
- A minor complaint, but due to the way the monitor is made the inputs are in the "neck" of the display so it's a big strange when VESA mounting it. Because of the hinge on the back the display always wanted to tilt upward a bit
ASUS PB298Q
Pros
- No PWM
- No input lag
- No ghosting
- Good backlighting
- No dead pixels
- Can OC to 75hz
- Best OSD out of the bunch, physical buttons. Two of the buttons double as dedicated buttons for quickly accessing settings. One allows for quick control of brightness, the other for volume. There's also a button for quickly changing the "Splendid" presets like most other ASUS displays have.
Cons
- Only negative here is there is a yellow tinted "blob" in the center of the screen. It's pretty noticeable on white backgrounds, especially when browsing since most web content is in the middle of the screen where the discoloration is.
i5 2500K @ 4.4
8GB RAM (DDR3 1600)
R9 290
