drtc
- May 19, 2008
I'm about to purchase a display as a second monitor to be used mainly for graphics and photo/video editing.
There are two monitors available here, within my budget.
The Nec 2090uxi at around 510euros and the HP 2475 at around 570euros.
I know these are quite different monitors.
The NEC is 4:3 and the HP 16:9.
NEC has a polarizer, HP doesn't.
HP is wide gamut too.
For overall use the HP seems more advantageous as it can display FullHD video content, has a newer panel, is faster, etc.
But I do not know how it compares as far as image quality, and black levels.
Have in mind that right now I use a quality CRT for my colour proofing, so I'm looking for a display that could match it as much as possible.
I have seen albovins' review of the 2490wuxi(not available here!) side by side with the 2475, and there is quite a visible difference in black levels and glow in viewing angles.
So does the smaller sibling 2090 share the same properties?
I'd truly appreciate anyone suggestion, preferably with first hand experience on these monitors.
ps: Also available is the 2690 priced at nearly 1200euros, with which I could buy both the2090 and the 2475 and get change
