2018 Macbook Pro Refresh FINALLY!
Discussion in 'Apple Products' started by zamardii12, Jul 12, 2018 at 9:46 AM.
  1. zamardii12
    zamardii12 2[H]4U
    2,280
    Jun 6, 2014
    Hot off the presses!
    https://www.apple.com/newsroom/2018...faster-performance-and-new-features-for-pros/
    • Quad-core i5 standard on the 13" w/ TB, i7 optional
    • Six-core i7 standard on the 15", i9 optional
    • Battery capacity increased on both models (by 18% on the 13", 10% on the 15") while keeping the same form factor. They may have switched to terraced batteries
    • 15" switches from LPDDR3 to DDR4 memory, allowing it to have up to 32GB RAM. Extra battery consumption is to be expected, but I guess that's more than offset by the larger battery capacity.
    • TrueTone displays (both the main screen and Touch Bar)
    • 3rd-generation butterfly keyboard. They're quieter, feel a little less clicky, but their design is still very similar. Unclear if reliability has improved.
    • T2 chip offers secure boot, flash storage controller, encryption, and Hey Siri
    • Up to 2TB of flash storage on the 13", 4TB on the 15"
    • GPUs are Iris Plus Graphics 655 on the 13", and 4GB Radeon Pro 555X/560X on the 15"
    • New Apple-sanctioned Blackmagic Design eGPU with a 8GB Radeon Pro 580 for $699
    New keyboard impressions:
    https://techcrunch.com/2018/07/12/the-new-macbook-pro-keyboards-are-quieter-but-otherwise-unchanged/
    Liver likes this.
  2. ND40oz
    ND40oz [H]ardForum Junkie
    11,643
    Jul 31, 2005
    About time, but why do we need to get the 15" to go to 32GB of ram. We'll give the 13" twice as many cores but still only give it 8GB by default and limit you to 16GB total.
  3. VulnoX
    VulnoX [H]Lite
    66
    Feb 3, 2004
    Looks like they are keeping the 13" with LPDDR3, only the 15" goes to DDR4, which I guess is allowing for the higher memory density. They seem to be offsetting the higher memory power requirements with the larger battery they fit in the 15". Someone at Apple I guess decided that whatever the runtime loss was by going to DDR4 on the 13" was too much with the smaller battery.
  4. ND40oz
    11,643
    Jul 31, 2005
    Yeah, it's a terrible decision on their part. My Late 2013 13" with 16GB of ram still has no upgrade path to more memory. I'm either stuck with the same amount of memory that I'm constantly using all of already with the 13" or I have to move to the 15" to get 32GB.
  5. 0ptional
    0ptional Don't Trust Your Friends with Your Decanter
    5,615
    Feb 22, 2003
    Waiting to hear about the keyboard, but I'm considering the 15 for myself, maybe dumping the gaming PC in the process.
  6. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,527
    Sep 24, 2001
    Correct, but if you're going to complain about that, I would also say that being stuck at 4 cores is just as much a detriment. As is not having a dedicated GPU.
    It's a balance between weight and performance for better or worse. Not that I'm disagreeing with you. I think we all wish we could get a 13" with a dedicated GPU, 32GB of RAM, and a hex core. I think we'd even also concede being willing to have slower options on both the CPU and GPU in order to still meet a specific thermal and power envelope. But it's not to be.
    Apple has consistently made their Macbook Pro line clear cut for at least the past 8 years, so we live with the compromises or simply get a different system (or I guess complain, but my underlying point is there isn't much point in doing that as Apple has spelled this stuff out).
  7. ND40oz
    11,643
    Jul 31, 2005
    They could have used the i7-8809G is they really wanted a dedicated GPU for the 13" but the GPU isn't important to me at all. Since I've been making due with 2 cores with Iris and 16GB of ram for 4+ years now, finally being able to double up to 4 cores and 32GB of ram would have been a good upgrade. Certainly would help with Fusion.
  8. Liver
    Liver [H]ardness Supreme
    4,421
    Oct 24, 2005
    Is it immediately available? Seems like it is, I’ve been waiting for the refresh to order one.
  9. zamardii12
    zamardii12 2[H]4U
    2,280
    Jun 6, 2014
    Yes
    Liver likes this.
  10. Liver
    4,421
    Oct 24, 2005
    Ordered a 13 inch for $29xx with taxes.
  11. csd
    csd Limp Gawd
    141
    Feb 8, 2008
    A shame that they don't offer the 6-core in the 13"... I'd prefer that over 32GB.
  12. zamardii12
    zamardii12 2[H]4U
    2,280
    Jun 6, 2014
    Nice. Once you get yours could you please please send a picture of your keyboard? I recently got my 2017 Pro with Touchbar back from Apple after going through the Keyboard Replacement Program and I am really curious if there is any way to distinguish between the 2nd Gen and 3rd Gen butterfly switches.
  13. Liver
    4,421
    Oct 24, 2005
    I will. My wife has the 2nd gen keyboard so I'll be able to look at them side by side.
    However from the linked article (in this thread), the keyboards are virtually identical.
  14. zamardii12
    zamardii12 2[H]4U
    2,280
    Jun 6, 2014
    That's what I was thinking. People are saying it definitely feels immediately different in a good way, but the mechanism is the same likely.
  15. Liver
    4,421
    Oct 24, 2005
    I’m replacing a first gen i7. I believe I bought it 2011.
  16. ND40oz
    11,643
    Jul 31, 2005
  17. Liver
    4,421
    Oct 24, 2005
    Not a bad option if no taxes. I got the headphones (promo) and Apple care.
  18. acascianelli
    acascianelli [H]ardness Supreme
    6,664
    Feb 25, 2004
    I'm disappointed that they're pushing the TouchBar models so much.
  19. TechLarry
    TechLarry Pick your own.....you deserve it.
    28,602
    Aug 9, 2005
    I have a first gen 15" i7 Touchbar (late 2016?) and I can't see any possible reason to replace it. It's a 16/500 and it works awesome. No keyboard issues. So far.
  20. SuperSubZero
    SuperSubZero 2[H]4U
    3,470
    Nov 21, 2000
    On the iMac Pro, the T2 chip introduces an interesting problem, as it's completely impossible to "netboot" it (Netboot is Apple's version of PXE). Many enterprises, including mine, use Netboot to do installations of the OS on older Macs etc. That they are moving this onto laptops is going to really throw a wrench in the works, at work.
  21. Guille_arg
    Guille_arg n00bie
    22
    Mar 7, 2013
