Clockworks
- Aug 23, 2004
What's in stock for next year? I'm looking at TVs now and some of the prices are pretty tempting but I'm in no rush by any means.
Panasonic Plasma if you want the best picture quality. Got my 50" 3D Plasma (top end model out of the three different series), $1350. They're as thin as LED TV's and produce MUCH better picture quality over any other display technology on the market (OLED doesn't count, laser is not very good).
Watching Avatar on this thing... it's just... amazing. Seriously, do yourself a favor and buy a high end, large, Panasonic Plasma (65" if you can afford it). Then, wait it out until a 50" OLED is only $4,000 and grab that
Personally, after having gone to PC Richards, Best Buy, and other stores, comparing different brands (Samsung, Sharp, Sony, Panasonic, etc) and technologies (LED, LCD, Plasma), I find that the Samsung LEDs have the brightest, sharpest, most crisp and vibrant displays. I'm sure Panasonic fans will tell you that the VTs have much better image quality, but from what I saw in person, in store, side by side, Samsung won for me. You should go to a Best Buy or wherever yourself and compare for yourself, everyone has different preferences.
I won't be getting another TV until there is one that allows 1080p120 to be input.
Why do you need 120hz input?
Honestly, my opinion is, if you're going to spend over 3k on a TV, you might as well buy a front projector (as opposed to a rear projector) for a full cinematic experience in the home. Then the size of your TV is only dictated by how large of a projection screen you purchase.
Nothing takes 120 Hz on the market except CRTs, which are used on the market. Still, that is a monitor, not a TV, and I wouldn't want a 42, 47, or 50-inch CRT TV. HDMI has the bandwidth but it just isn't written in the standard as a supported format.
Vivatek Qumi will also take 120hz signal. There are more out there than you think, it is just over VGA and not HDMI.
A projector is not a display, the screen is. This thread is about HDTVs. They're fine if you want a theater that is dedicated for that and dark, but most people don't sit in the pitch black to watch TV.
I used to be able to play fast paced games (shooters) without much issue. For the past few years, I've been getting queasy, motion sickness whenever I play for more than 10 minutes at a time. I would need to take breaks else I would want to throw up. Since then, I've resorted to strategy games (which is fine since I like them) but I would like to return to some shooters if possible.
With that said, is 120hz better for my situation? Would there be a difference between a 120hz TV and a 120hz monitor?
My wish list:
1) Full-array LED
2) 240MHz (120/eye 3D)
3) 4K resolution
A 120 Hz monitor is 120 Hz. A 120 Hz TV just makes up fake frames from a lower source frame rate.
240 MHz!?!
My wish pertaining to LEDs is that they would stop farting around with OLEDs and get back to trying to make a display with traditional LED technology.
Some people want it to be able to play cinema and broadcast without having to deal with slow and annoying display mode changes, and because of processing. Pretty sure a small minority of people even want a dedicated theater room.
