2007WFP vs E228WFP vs 2 cheap 19 inch acer's
R
ring.of.steel
Guest
hi guys, looking for a new monitor as im stuck here with 2 15inch CRT's
I have seen bad reviews about the E228WFP, is it a crap monitor? as for the 2007WFP i have heard it is a great monitor but is it worth loosing the extra 2 inches?
My final option is to get 2 Acer AL1916WS but i suppose they are crap compared to the dells?
cheers
what's your budget?
2 x 2007WFP would pwn all if you can afford it. I wish I had done that instead of 1 x 2407WFP.
two of them is way out of my price range. budget is the price of one 2007WFP, and im struggling to get that lol.
cheers
Unless you just absolutely have to have dual monitors...the single 2007FPW is the way to go. The added features and picture quality will more than make up for the loss of 2" vs the E228WFP.
