Although not tech related we may have a few riders here. This is not a garage queen but rather a VERY fast bike that was ridden every chance i could get. It also was my first bike. It's time someone else enjoys it as much as i did.
Here's the deal...I'm pretty much forcing myself to sell the bike. I want to put myself in a better financial position in life and get my bearings straight for the first time in a long time. The Busa was fun and i WILL have another bike...just not right now...
THE DETAILS:
2006
83xx miles
Was the fac tory black/grey metallic - Now is Primarily Sunburst Orange metallic and needs paint job finished
I have the seat somewhere & the grab bar is also here. the Solo seat cowl is notched for grab bar clearance.
I will not lie about the bike's history. The bike was tipped over on each side within a week or two of ownership because it was my VERY FIRST BIKE. Mirrors are scratched up as a result and the black clutch cover does have some marks on it. Also it was down in a small accident on November 6th, 2008 that resulted in ONLY PLASTICS DAMAGE and all damage sanded out in prep work for the Sunburst Orange Metallic partial paintjob. I also replaced the front turn signals with smoked ones. THERE WAS NO OTHER DAMAGE DONE TO THE BIKE. Currently the front fender & tail section are stock, the solo cowl is blue, and the sides/tank/upper are all orange. paint just needs to be completed...It has scratches & marks from regular riding and is not perfect. A Wet Buff would go a long way toward fixing most of that in the orange...It was a daily rider when the weather was good enough to do so...she wasn't a garage queen...
MODS:
5 position dogbones - currently set at 2" lower in the rear
Lowering Strap for front forks
Custom Kickstand - it has 2 points on it and could use a 3rd. It was modified to allow the bike to lean while completely slammed to the pavement. at 2" under it's "adequate" - at stock height it really needs a position in the middle for optimum lean. this can be accomplished by drilling the stand and adding another adjustment hole.
Brock's Streetsmart Full Exhaust - Exhaust was received from a forum member and was heavily damaged. I repaired header tubes 2 & 3 by cutting out the bottom half of each tube and welding in new stainless steel. The muffler also had a hole which was patched with a metal fill compound. Exhaust works as new and shows in the trap speeds.
Small Box Mod
PCIII w/Brock's Map
BoostBySmith ECU Nitrous Harness
Bike is setup for ECU flashing
Flashed with revised timing tables & enabled flapper solenoid for NOS use
BOTTLE IS NOT INSTALLED! - Power wire needs hooked up for harness to fully function. Activation Switch & pins for your solenoid will be included
I have installed the 4"+ swingarm with help from wildphil. It turned out great.
I used a EK DR2 non-oring chain
Also has new 43T rear sprocket on it.
SPEEDOHEALER NOT INSTALLED!
MAINTENANCE NEEDS:
Front Tire - about gone - rear is a Pilot Power 2CT with about 2k on it. still looks to have a TON of life left.
Fork Seals - just discovered this a couple days ago & haven't had time to get an estimate on repair.
I HAVE BOTH OF THESE NEW AND READY TO GO ON THE BIKE. Tire is matching Pilot Power 2CT and seals are NEW OEM from Schnitz Racing. If purchased before installation they will go with bike.
WHAT WILL GO WITH BIKE:
about 8-9qts of Mobil 1 Full Synthetic 10w40 4T Racing Oil for Motorcycles - this is ALL i have run in the bike since day 1 - it's GREAT STUFF!
My ECU Flashing harness - it's custom made...without it you're gonna be pretty screwed.
Anything else HAYABUSA related i can find.
VIN: JS1GW71A062108946
I can provide some detailed pics upon request. Price is FIRM at this time. Title is held at my local bank but i am not upside down on it. Would take about 10min to get for a local sale.
http://mysite.verizon.net/fubar569/newbike1.jpg
http://mysite.verizon.net/fubar569/newbike2.jpg
NEW PICS ARE HERE!!!
http://www.failbardave.com/pics/busa pics 001.jpg
http://www.failbardave.com/pics/busa pics 002.jpg
http://www.failbardave.com/pics/busa pics 003.jpg
http://www.failbardave.com/pics/busa pics 004.jpg
http://www.failbardave.com/pics/busa pics 005.jpg
http://www.failbardave.com/pics/busa pics 006.jpg
http://www.failbardave.com/pics/busa pics 007.jpg
http://www.failbardave.com/pics/busa pics 008.jpg
Those are links to the NEW pics showing current condition as is and ready for sale. i'll warn you first that they are HUGE. they show some scratching on the right side fairing and the light clutch cover scratching as well. Figured i'd be as up front as possible.
SCHEDULE: i work 4:30pm-1am and my days off do change. I have every other weekend off however. My bank does not have weekend hours.
CONTACT INFO:
PM
[email protected]
Cellphone: 814-331-1292
I need to get some Updated pictures that show the paint & swingarm. These are coming on the next good weather day.
Thanks for looking...and spread the word...if it sells due to a lead you generate i will compensate you with a beer/sandwich or something. lol.
THE DETAILS:
2006
83xx miles
MODS:
Small Box Mod
PCIII w/Brock's Map
MAINTENANCE NEEDS:
CONTACT INFO:
PM
[email protected]
