Hi All, first post on this board but ive been reading a fair bit on here lately, primarily all the posts on the Dell 20" widescreen.
I finally decided to get one as they were selling at about £330 which seemed a pretty good deal.
I was aware of the backlight problems and to be honest wasnt too bothered by it as every flatscreen I have used so far has this issue to some degree. However, it arrived on Saturday and I have a few problems.
Firstly the backlight bleeding is pretty bad in the bottom left corner, I could live with this if it was the only issue to be honest.
There is a pixel stuck on 'red' right in the middle of the screen which I dont notice when gaming but is annoying when using white backgrounds in windows.
The power cord is faulty. If you touch it you can hear a small 'fizz' sound and the power sometimes cuts out. I tried another cord and its find so I'm sure its the power cord thats at fault.
I'll be getting this one RMA'd because of the above, however I also have an issue with the S-Video in on the monitor that I wanted to run past you guys to see if this is common problem or not. Bascially the picture is coming through balck and white with a whole load of intererence. It's an svideo connection from a vcr and if I use the same vcr/cable and plug in into the s-video socket on my tv its fine, so no problems with the vcr or cable. I couldnt find any settings to configure with regards to the s-video port in the monitors menu so I am assuming its faulty.
Has anyone else seen this problem or am I missing something that I need to do with this monitor?
Any thoughts or comments on my 'not so successful' first 2005WFP issues would be appreciated
Cheers!
Cheers!
