2005FPW with HDTV box can do 1920x1080!!!!
rcrez
I recently purchased both a Dell 20" Widescreen LCD 2005FPW and a Samsung SIR-T451 HDTV Tuner hooked up using DVI. There are four resolution settings on the tuner and they are: 480i, 480p, 720p, 1080i. The 480 modes run in 720x480. When selecting 720p, the 2005FPW uses a 1280x720 60Hz resolution
Now the interesting thing is: when I select the 1080i output, the 2005FPW blinks out momentarily, saying that it can't display that range, then suddenly restores the video! When I click the menu button on the display, it says the resolution on the 2005FPW is currently at 1920x1080 30Hz!! In case you don't know, the maximum resolution on the 2005FPW is 1680x1050. As further evidence that I'm actually using the higher resolution, when I open up a menu for the HDTV tuner, all the fonts and text boxes look much smaller. I must say that the image completely fills the screen with the correct aspect ratio when using 1:1 or Aspect. The LCD is not a window into a larger area like what my computer does when I choose a resolution greater than the LCD max.
How is this possible? Is the monitor somehow accepting the 1080i signal and converting it to some lower , but usable resolution? If so, is it converting it to a resolution higher than 720p? Is it using the full 1680x1050? Is the 1080i signal superior than the 720p as a result of this interesting fact?
Still, how can the 2005FPW be handling the 1920x1080 signal properly?
the native resolution of the panel is 1680x1050, and that's all you'll ever see regardless of what resolution you've got it set at. the controller can probably handle the higher resolution and is interpolating.
Not surprised... its called a scaler. All LCD monitors use them to display non-native resolutions. The scaler determines what resolutions your monitor can support in scaling up/down to the panels native resolution.
As for 1080i, this is no big deal. Actaul resolution is 1920x540 (to simplify... you have two sets of 540 vertical lines are interlaced to give you 1080 total lines of information, problem is, they are never displayed together at the same time). So, you get 1920x540... but wait... most 1080i broadcast content is actually filmed at 1440x540, so you're not really even getting the full 1920. 720p, IMO, is much better than 1080i, but that can depend on the content and what you are using to display it with. 1080p owns all. :D
How do you know its shrunk down to 540 or what not? Is there a spec somewhere that says what its scaling down to? Why not resize 1920x1080 to 1680x1050 or whatever?
ratio's would get screwy...
Also check out how broadcast 1080i scaled to 720p on HD's looks like crap compared to 720p broadcasts..important since the vast majority of HD sets sold max out at 1280X720 or 1024X768
Its all about the scaling ratios..
I can do 1920x1080 on my 17" NEC LCD just using the video card in my computer. It looks like crap because it's using a scaler but it can do it.
