2005FPW USB Ports
p0intblank
How come they aren't working for me? I installed everything just fine when I get the monitor a a month or two ago.
Did you connect the usb cable that came with the monitor? You need to connect it to the monitor underneath by the DVI connector. I forget what the cable is called but it has a square-ish end and a normal usb connect on the other end. The cable needs to be connected into your computer's usb.
Oh sh*t. :p Well I feel stupid now. I was wondering where that cable came from that's been sitting in my notebook bag. LOL
Dont feel bad, I was wondering the very same thing. Thanks OP.
when i got purchased my 2005fpw i didnt even know their was a 4 port usb hub on it, it was just an icing on the cake which i gladly use for my ipod and mouse
