tgscordv6 said:Mine is perfect.![]()
BigDuallie said:I've had mine for over a week and I haven't noticed any problems with it at all. I just fired-up the Matrix DVD and turned off all the lights in the room and the backlighting was consistent through the whole screen. I have a gallery of pictures over here.
synack said:It would be extremely helpful if you could post one of the pictures with the Matrix DVD in a dark portion of the movie.
PsySabreW said:I got mine last week. I did have some slight backlight leakage on my upper left and bottom right corners but that's disappeared. Altho mine did come one 1 dead black pixel in the upper right corner, 2 stuck green pixels on a black background and 1 blue stuck pixel on a black background (You really have to look to find them tho).
Warborn said:Where is everyone getting these coupon codes from? I'd like to order the 2005, but after seeing on Dell's site less than a month ago for $630 I can't stomach paying $800 now. Anyone have a coupon code they aren't going to use or know how to get one?
fallguy said:One sample pick, I got a lot more, but dont have time to post them right now.
firey-eyez said:hmm i just noticed that my graphics card (gigabyte 9600XT) doesnt have an option for 1680x1050. is this because the screen i have now doesn't support that res, but if one that did support it was connected it would show up? if this is the case, that is interesting because 1280x768 and 1920x1200 both show up.
jhzero1984 said:Just got my 2005FPW today and I am impressed with the quality (first LCD screen). I do have 2 1/2 dead pixels (one is slightly stuck, changes but not to dark colors, kinda weird) with only one actually bothersome (bad spot) but no backlight issues when running a couple DVDs.
http://kdelook.org/index.php?page=2 - has some decent ones.firey-eyez said:now for the next issue; wallpapers. could anyone tell me where they get their 1680 res wallpapers from or what some good ones are? there have been several nice ones in this thread and in the similar ones over at firstadopter forum (i post there under the alias CraZyKoKeNo...say hi to me if your there ever ^_^).
edit: just hopped over to deviant art and saw that they have a good selection of 1680 res wallpapersguess i never noticed it before. nevermind my previous question then.
RADON said:Well, for some reason I was not able to reproduce the red lines as previously stated. I'll chalk it up to a fresh install of windows w/o updates.
However, it seems as though there is slight bleed thru on the lower left and top center. It's not as severe as Dew's, but it does bother me. Should I be concerned or even bother to try for a replacement as the replacement could be worse?
http://silentspin.shackspace.com/Dell/2005FPW 010.jpg
http://silentspin.shackspace.com/Dell/2005FPW 012.jpg
I've purchased and used about 13 different LCDs over the last few years... Some for home, some for work... This is easily the nicest LCD I've had at home, and it's on par or better than any of the LCDs I've used (including high-end ones from Planar, Viewsonic and Dell) at work.synack said:BigDuallie thanks for upping the dark screen photos. It's good to know that the backlight leakage isn't spread across the board. Is this your first LCD or can you compare it to others that you have owned?
