2005fpw receiving no signal during boot.
I just got a dell 2005fpw yesterday and so far its great except one major problem. During boot it does not get a signal from the video card, or rather it can't display the signal that is sent to it. If I hook it up using vga then I get a signal at boot, but with dvi it just won't go. Once my xserver boots up (i use linux) then the display works perfectly fine. I am currently running a radeon 8500 all-in-winder. I have no clue as to what I can do for it to get a signal.
Hmm I have the same monitor on a AIW 7500 using DVI and I get the BIOS bootup screen. I'm using XP. BUT O/S shouldnt have anything to to with the bios display screen. Maybe a bios setting?
this has been covered before...
shut off computer
unplug cable from video card
connect dvi to monitor turn off monitor
turn on monitor
adjust monitor so it's showing waiting for dvi (#2 on my 2005fpw)
attach dvi to vga card
boot computer
you shouldnt have any issues any more, hope this works for you...
shut off computer
turn on monitor
boot computer
I tried that but still no luck. I tried out a different video card and then the boot screen shows up.
