2005FPW PBP with 2 computers?
Strykar
I just got my 2005FPW today and am playing around with some of the features, I wanted to know if it were possible to run PBP mode with a second computer? Seems like you can only use composite or S-Video connections as D-SUB is marked grey and im currently using DVI.
Btw, yes I am ABSOLUTELY loving the monitor, just played HL2 at 1680x1050 and wanted to drool all over my keyboard, normal browsing is sooo much better than squared resolutions. I just sold my Hyundai L90D+ to a friend (no problems with it, just wanted something bigger and black..... that sounds horrible Razz )
[BB] Rick James said:
What is the response time on this monitor? I'm looking at getting it.
It's a 12ms 20' with a native res of 1680x1050. Gaming is just spectacular, not many games support widescreen natively yet but a lot of newer ones have hacks out, check: Widescreen Gaming for more info.
I was expecting to use this later this evening.
I thought you could run PBP using DVI from one computer and using VGA from another? Perhaps tryin plugging in another computer and maybe it will be recognized.
That's what I assumed would work, but the options to use DVI and D-SUB are completely greyed out whether using the monitor on DVI or D-SUB for the main system. It should not be greyed out I thought, ive seen screenshots where it is selectable in the manual like s-video and composite are.
