2005FPW Mount Issue
havalon
I am looking for a flush wall mount for the 2005FPW. I can not seem to find one that fits because of the inset for the stand that Dell provides. Has anyone had any luck with a flush wall mount for this model?
I really hope so because modding the plate I have won't be fun. The metal is a bit thick.
Can you use a mount that is not flush, but does not protrude much. Check out Sanus. I have the VM3b and absolutely love it. They are machined out of aluminum and are very sturdy. You should check out the VM1 or VM2. Those should definitely work.
I believe that may work, but it is a bit late. At least right now. I have already took a hack saw to my old wall mount that didn't fit. I am half way into one side.
Issue resolved. Took down thee sides with a hacksaw. It is a mount and hidden so it didn't need to be pretty.
