2005 fpw n00b questions
Hi all,
I'm new to LCDs and I just got my 2005 yesterday, but I wasn't sure if I had a problem with the backlighting. When looking at something black, it seems lighter in a few areas than the rest, especially the top middle and a bigger portion on the lower right corner. But that also changes I think at the angle which I view the monitor at. My question is, is this a backlighting issue, and if it is, can I fix it or possibly get it replaced? Also, how can I check for dead pixels?
Thanks for your help guys.
that's called bleeding. Usually, if it happens on your monitor, it happens on all other monitors of the same type (i.e. RMAing it won't fix it, you're stuck, or sell it and buy something else.). As far as checking for dead pixels, you'll have to do visual inspection. The best way to do this is to make your screen all black, all white, all blue, all red, and all green. You might try hiding your desktop icons and changing your background color with no background image. Or if you feel like wating around, PM me and I'll write you a qbasic prog that will do it for you.
Thats not true, some 2005fpw are near perfect, some are awful. ..
I would suggest doing an RMA just once - and if the replacement has the same issues just return it. I have friends that exchanged the 2005fpw 5 times and still didn't get a perfect one. It's really luck of the draw unfortunately.
