2003 in 3dmark03 .... wtf
KillToy
what the crap... sholdnt i be doing better than that with the comp in my sig?
I got 5300 with my setup, yours does seem way low!
Try running it again, sometimes it gives funky scores.
k i was looking around at score for similar setups and i was shocked to see mine soo much lower.... what could be causing this if its not just the 3dmark?
Is vsync on? If you go to run then dxdiag and look under the display tab is agp texture acceleration enabled? Do you have the newest video drivers and chipset drivers etc.?
ok yea soemthing is definatly not right... ran it again and got a 1700 i will try all the things you said jim in th emorning
Definatley low. I get better than that with my 9600Pro. Which is sad because it doesn't score that great anyway.
