2001FP panel is tilted!!!! helps!
chinese
Just got my 2001FP today but after I connect the panel to the stand, it's obviously tilted and I spent the last 30 minutes trying to adjust it but haven't had any luck. The only parts that look like I could actually remove would be the four screws on the part of the stand that connects to the back of the panel but it doesn't fix the alignment problem. Is it possible to ask Dell to send me a new stand and I can ship back the old one to them? The reason I'm asking is because the panel itself is perfect--no dead pixels and no backlight problems--so I'd like to hang onto it.
Titled which way? The stand lets you tilt the monitor in all directions. You can even rotate the entire monitor 90 degrees.
I guess I just can't visualize where the problem is. I just tilted mine in every direction trying to figure out how it could be so messed up that the normal movements couldn't adjust for it. :confused:
It's tilted about 5-6 degrees downwards on the right side, so basically the right side is drooping down a bit in its natural position. I'm gonna return the panel anyways, the bad color reproduction and slight screendoor effect is giving me more eye strain than my 930SB crt.
OH Troll please! you sure your not drunk and trying for some flames. Why you buy in the first place? Go get a 14 inch CRT and complain about the size?
