2001FP discount
New Start
How do I find one of those sales or coupon codes for the 2001FP? I would like to order it, but it's $750 right now.
It's $750 in the small business section, but $675 in the home user section. Just yesterday I think it was cheaper on the small business page. And a lot cheaper on both if I recall (some sort of discount).
There are some businesses (Dell especially) that you'd be crazy to buy something if it wasn't on sale. Because they have huge sales just about every other day. Very frustrating.
YOU FOUND IT!
I was going crazy last night trying to figure out why it went from $750 to $675 in 5 minutes!
BTW, this morning they have $75 off: 5M2MX6BK0P?QDW
Plus free shipping and the 10% off monitors mentioned above.
New Start said:
YOU FOUND IT!
Yep, I just grabbed a 2005FPW for $599 shipped using the above code.
Do you have to install any drivers for this monitor, or just plug it in an go?
Also, what cables/accessories come with it?
I don't know about this one but our company bought a number of the widescreens and they come w/a DVI and analog connector as well as a USB cable for the panel ports. You should install the inf for the monitor just so that Windows will know what monitor it is dealing with and give you all the resolutions and such that it supports.
Where do i get the driver for the monitor? The only cd it came with is a documental cd.
The drivers for the 2001FP LCD are located on the root of the CD itself. If you take a closer look at the files, you will see the INF files needed to update the monitor driver for your 2001FP.
