2001fp delay problem
Nolemiah
so I've had this problem with my mouse for quite some time where it seems to kind of drag. in other words, there is a slight(very slight, but enough to make playing fps a little annoying) delay between when I move the mouse and when the cursor moves. i've tried other mice and they do the same thing. but when I hook my computer up to a different monitor all of a sudden it all works perfectly. it's a different lcd, one of lesser quality even. has anyone else with a 2001fp had this problem? and if so, what did you do to fix it? thanks!
Never seen or heard of that. It seems like some sort of software lag more than a LCD issue. Maybe the USB ports if you are hooking them up? Not likely but who knows.
I just ordered my second 2001fp today for 464 and can not wait. I have been wanting to have two of them side by side since I got the first one for 700 but just no time to sit and remember to order it. So next week I will have a clean desk with a pair of them instead of one with a big 21 crt as my second display.
Sorry could not help, but that problem is new to me. I would go to the dell forums for 2001fp issues, its packed with good info.
i had some lag issues with my 2001fp with my 9800pro. Then I saw the driver disk that came with the LCD, installed it and no more problem
I have the same problem and have yet to find a fix for it. It has to be software related because I don't notice it in Linux. To reduce the mouse lag, go tto:
Display Properties -> Settings -> Advanced -> Troubleshoot
Then move the slider bar one notch to the left of "Full". That seems to help.
i'm still having lag issues! can anyone help? I tried installing the drivers and I tried posting on the dell support forums. still nothing. i actually resorted to buying a 21" crt(cheap, like 100 bucks, crappy but it does the job) just to play games on. can anyone help?!
Did you ever figure out what was causing the delay? I see the same lag on my 2001FP , I can clearly see it when running both of my monitors side by side (Clone mode on a 6800GT) ,the other monitor is a Sony 21" CRT G520P. This lag cant be good for online FPS gaming.. I still have time to send it back to Dell for a refund.
