I need help building a gaming rig and need everything except monitors.
Gaming, light multitasking (browsing, IM's, playing videos)
$2000 with a bit of flexibility either way
Shipping to Canada is necessary (newegg.ca is great or directcanada.com, ncix.ca, canadacomputers.com are a few others)
3) Where do you live?
Nova Scotia, Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except monitors, will be using dual 24" LCDs
So,
CPU: i7 920 maybe or a Core 2 Quad if it's good for gaming?
Motherboard: anything compatible (SLI/Crossfire capable if dual monitors can be supported) Would like to have LGA1366
GPU: Crossfire/SLI would be cool if it can support dual monitors, TVout would also be nice but not necessary. Anything have HDMI outputs?
RAM: 6GB+
HDD: 1TB storage, maybe SSD boot if its within budget
CD/DVD: DVD Burner
CASE: Simplistic looking, nothing flashy
Blu-ray: Not necessary
Just Monitors
6) Will you be overclocking?
No, but open to suggestions.
2x24" at 1920x1200each
In approx. 1 week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Including addon cards:
- ~6+ USB ports, 2+ Firewire, Crossfire/SLI (If dual monitors are capable), 6+ DDR3 DIMM slots
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
11) Anything Else?
- Card Reader
- Slick and minimalistic case. No lights or windows.
- Will be buying from newegg.ca, directcanada.com, canadacomputers.com amazon.ca
Any help is great!
Thanks
Nova Scotia, Canada
So,
RAM: 6GB+
CD/DVD: DVD Burner
Just Monitors
In approx. 1 week.
Yes
11) Anything Else?
- Card Reader
Any help is great!
Thanks
