2.2v and 5-5-5-15 should work... if the RAM can do it.
well i have the voltage at 2.0 and the memory is at 1000mhz stable. im just wondering if this is safe... it seems like a big jump.
better yetis it safe to go further if it will alow me?
What do you consider "stable" by the way...?
ok thanks. i might just try hitting 1100 or 1200 thenThose are amazing numbers. If you feel like you need more speed, then it wouldn't hurt to increase the voltage a bit.
Memtest is the true test for memory
im just worried about heat. is any of the heat bad for the memory?
is heat bad? yes heat is bad
i guess if all my other temps are allright then the memory should be fine right?
never assume anything. there is no temp sensor on RAM usualy. you need one of those hand held temp guns to check accurately. but usualy if you can tollerate pinching the stick between your finger and thumb (careful not to move the stick) for more then 5-10 seconds its ok. if your skin sticks to the heat spreader, its too hot. talk about "rule of thumb"if you increase the ram voltage more then 1.5-2.5 tenths of a volt (+0.15 - +0.25) you probably want to angle a fan to blow across them.
well i have got the 12 cm fan the blows across my hard drive to the memory i will test how hot the heatsinks get here in a minute...
EDIT: i just loaded Flight simulator X and flew for around 5 minutes and then put my fingers on the first stick of memory and it wasnt hardly hot at all. i could sit there all day with my finger on it. well.... not really but it wasnt hot.
ok but what programs monitor memory temps?
