$200-250 to spend, 22"?
I'm looking to buy a 22" in the $200 area. It will mainly be used for Logic and gaming. Viewing angle doesn't really matter. Resolution does though, I'd like to go as high as possible. I wanted a 24" but I have a maximum width of 21.4 inches to fit the screen in my desk..
Thanks!
The monitor size is measured by the diagonal across the display, not the width. I would imagine that most 24" monitors will fit into your desk area. For example, the Dell 2408WFP is only 22" wide (bezel included). However, there's no way you'll get a 24" within your price range.
Wow, I remeasured my desk and realized why I thought I can't have a 24" screen: I only have a 21.4 inch width to fit it (I edited my first post too).
So... I will go $200-$300 on a 22" screen, what should I go for? And I would love a 24" if it fit.
If you like glossy LG227wtg-pf
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005109&Tpk=l227wtg-pf
If you like matte LG W2252TQ-TF
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005112
I had a g520 and a p1130.
I Waited to long to jump on lcd.
These are both the exact same LG panel.
They are 1000-1 static 10,000-1 Dynamic CCFL backlight
11-21ms input lag when gameing analog 10-19 dvi
Although i noticed no diffrence from VGA and DVI. The VGA is excellent.
2ms g2g ghosting/ 3-6 ms variable for all other colors
1/17 of an inch backlight bleed on top and bottom center on solid black image.
blacks are really good for a tn panel. one of the best the DCR is very fast.
HDCP Complient. Also I haven't found wheather this has 1:1 pixel mapping but if it doesn't
I would be surprised. It looks damn good and hasn't stretched my screen.
no banding as long as you dont go below 70 and use these settings.
The best settings. is 51 red 49green 48 blue. brightness 73 contrast 70 gamma -50
then software wise leave everything the same but gamma bring to 42 from 50 if using nvida control panel. Absolutly stunning image. I play in the dark so i like glossy. im assuming that the 2nd choice has the same setup.
trust me buy it from best buy and hook up well worth it they have it on sell for 279 right now!
