I'm trying to put together a triple 20" (or greater) setup for under $600. I'm really shooting for bang-for-the-buck here. I do the occasional gaming/vid watching/photo editing, but mostly I'm in it for the real-estate. I know hoping for anything but a TN panel under $200 is silly. I just want the best I can put together for the price. I may go for a non-TN center LCD then TN's on the wings to try and get the best of both worlds, but they would have to be nearly identical in physical appearance (i'm big on symmetry). I'm stepping up from a single 17" CRT, so I doubt I'll be that disappointed by TN's.
I was leaning towards three Dell 207WFP's as they can be had for under $200 each. That would give me the option to do a Dell 2007WFP in the center and 207's on the wings (if it's worth it). Newegg has at least half a dozen 20" widescreen monitors for under $200, the cheapest being the SCEPTRE X20WG-1080P. They also have a BenQ G2000w, and a ViewSonic Q2162wb (21.6"! but no DVI) under $200 after rebate. I really don't want to drop $600 on monitors just to find out I screwed the pooch, so any and all help is appreciated.
