OK so I got a new rig, and I had an Rhycom ATX P4 550W psu.
When I was putting it together I noticed the new 24 pin set up. SOO I had to go out and get a 24 pin connector for my A8N-SLI Deluxe so the 20 pin would work. The power source is ATX 2.03 and ATX 12V 1.1 complient. So I'm thinking that it should work fine.
I"m about to re-sleeve the PSU and I was thinking, wouldn't there be a way to just double up some wires from the 20 pin and follow the same way the 24 pin was put together and just use a new 24 pin connector on the PSU when I re-sleeve it?
Should I have gotten a new 24 pin PSU? I"m looking into some of the "X-Connectors" but I can't seem to find one with a 24 pin set up?
Thanks for your help guys
p.s. if you can recommed any PSU's with the X-connector type deal for me that would be great too
