ExtremelyWoke
- Jul 8, 2004
Hi I'm looking to spend no more than $540 on a new 20 inch LCD widescreen. The LCD will be primarily used for FPS gaming.
I've heard too many bad things about the 2005fpw and the 2001 to consider either one of those (backlighting and minor ghosting).
Should I consider the Acer AL2032WA Black 20" 8ms wide-screen LCD Monitor or the SCEPTRE X20G-Naga III Black 20.1" 8ms 16:9 Wide Screen LCD Monitor? Why is the Acer $530 but the Sceptre only $400 but they both have the same specs.
I would consider that new gateway monitor but I heard that half of the screen is brighter than the other half.
Any suggestions?
Any suggestions?
