Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The title says it all, do you have any recommendations for this kind of rack, I only found Middle Atlantic.
Depth 17inch should be enough for router, switches, sonos, modem and synology nas.
And, if you want cheap just mount it to backboard which you'll need anyway. Benefit is it doesn't stick out and hit you in the face if in a walk way and you can paint it to match your wall color.
