20-22" Best Choice?
MarkusSelv
Hi All,
I'm looking for a decent monitor (in the UK) either 20.1" or 22" WS. It's going to be paired in a dual monitor setup with a non-WS 19".
It's going to be used for game development, gaming but also some web design so it needs to be able to produce reasonably accurate colours, my main choices were probably:
Dell 2007WFP (Guaranteed S-IPS A04):
Pros - True 8Bit, Portrait Mode
Cons - Since it's being paired with a non-WS 19" it might seem very small in height. Plus the lower dot pitch might make text a little harder to read?
HP w2207
Pros - Cheaper, Almost exactly the same height and dot pitch as the 19", can also go portrait, glossy (this might be a con, not pro, undecided)
Cons - 6Bit Panel, + all the other nasties that go along with a TN Panel?
Which would you go for? Are there any better alternatives around the same price (£250 max). I'd appreciate any opinions.
Thanks! :)
I searched the Dell because I too am looking for a monitor around 20-22". I came up with this, citing bad default settings. I also noticed on the right it listed various retailers selling the monitor for almost $400. Didn't you say you were looking in the $250 price range? Where exactly do you see this thing for that cheep? I am looking for a monitor in the US.
Anyway, here is the review.
http://www.pcworld.com/article/id,125925-page,1-c,monitors/article.html
250 pounds, not dollars.
I'd go with the 2007WFP and be done with it. Can't go wrong if you get an S-IPS.
