2 xbox 360s, 1 dsl connection. will it work?
rusty
so im about to buy my own 360. my brother also has one and ive heard of some trouble getting both 360s to connect to Live with seperate accounts at the same time. I figure that someone has to of found a way around this "Open NAT" situation. apparently only 1 xbox will register the NAT type to be Open and the 2nd xbox will have either moderate or strict??
does anyone know of a work around to enable 2 xbox 360s to work over Live with no problems at the same time?
I have the following routers:
Linksys WRT54G, WRTG54GS, and BEFSR41. I can connect the xboxs through cable or wireless, doesnt matter.
any help will be greatly appreciated.
go hokies.
I run two of my Xbox's on Xbox Live simultaneously all the time with no problems. I just opened the ports for one of the Xbox 360's but i seem to have no problems getting the second (or third) ones to connect and play games at the same time on Xbox Live.
I'm using a Netgear WGR614, Billion 7407VGP and Linksys WRT54G with DD-WRT firmware.
so basically you just opened the ports for one of your 360s and thats it? no messing around with uPNP or settings for the 2nd 360?
A friend of mine who has a linksys router used to have the same problem when we used to both play halo 2 on his connection, this was with original xboxes though. He fixed the problem by upgrading his router's firmware to the latest one.
We've got 2 xbox360s on a DGL-4300 and a WRT54G respectively. Just plugged'em in and everything worked right off the bat.
Yup, i tested this out last night and everything worked perfectly. Had one running on wireless and the other through a cable. Everything worked great when we had 1 console running halo 3 on live and the other running a live match in Fifa 08. this was on a WRT54G.
Yeah, I have friends that used to run 3 or more normal Xboxes and Halo. Right now they have 2. One is hard-wired and the other is wireless. No issues at all.
rusty, what did you do? i am currently having the getting booted off issue when one signs on...we have one wired and one wireless with 360 adapter...
what did you do?
We've run two 360's at the same time, and never had any problems with the D-Link router we were using. Prior to the 360 we sometimes had 3 original Xboxes going simultaneously.
I had this same problem, with 2 xbox 360's on a Linksys router.
I exchanged it at best buy for store credit and picked up a Dlink DIR-655 Xtreme.
This router kicks butt, ive had no problems yet and its much faster.:D
We ran 8 360's at our Lan party earlier this year. afaik, we didn't have any issues with them all connecting to live at the same time. Router and switches were all Linksys brand and we were on 15meg Cable connection.
