newls1
- Sep 8, 2003
Pondering the idea of ditching my 4x8gb sticks of "B" Die Gskills for a pair of 2 x16gb of ram that will get me 3600+ speeds and still stay in the CL16 zone.... so, with that said, here are my questions:
1) do you think ill be able to switch to 1T command rate using 2 x16gb sticks (Where as on my current 4 stick setup i cant)
2) Is there a good set of B Die 2x16gb sticks out there?
3) should i just keep what i have and not do this?
Currently my 4x8GB sticks are @ 3635Mhz @ 1.39v 16/16/16/35 38tFAW 2T Command...... Just looking / hoping that i can atleast achieve the same OC using 2 sticks while having the same capacity, and gain the same stabilty @ 1T. Ideas and help are appreciated! and hopefully you can link me to something you recommend!
