2 Video Cards non SLI - PROBLEM
PK*
Hey everyone...can use your help as I'm stumped at this point.
I'm trying to run 2 video cards simultaneously, non SLI, to accomplish a 3rd monitor added to my current dual setup. The primary card is a 9800gtx and the 2nd card is a 7800gt. When I installed the card, the device manager sees it no problem but it seems to be sharing the drivers from the previous card. Any time I enable the 2nd card I get a blue screen. The NVIDIA driver page indicates that these cards use the same drivers so I'm not sure how to go about running these together. There's obviously a conflict.... or user error. I tried completely wiping out my drivers and reinstalling but it only prompted me to install once and both cards seem to be sharing the drivers.
Asus Commando
9800 GTX
7800 GT
Windows 7
Any ideas?
As far as I know, they have the be the same generation (or at least use the same drivers).
They do not need to be the same gen, I'm running a GTX275 and 9500GT no problems.
Nvidia lists the same driver for both cards. My PSU is 620w so I don't believe that's the issue. The only way I can get the 7800gt to function is if I remove the 9800GTX.
Thanks for the replies, please keep them coming if you have any ideas.
My combination is GTS 250 and GT 240 and no problem so far. I have not done 3 monitor yet. Thats coming soon It works fine on my W7 x64.
Saedrin - I picked up a PCI card with equivalent shaders, DX, and WDDM and all 3 monitors are now successfully viewed. Now my new issue is the Windows 7 Aero being disabled any time I plug in a 3rd monitor. Are you successfully running Aero on windows 7 with your setup?
