2 Velociraptors Short Stroked or 4 Solid States?
Justintoxicated
I see you can get quite a bit of speed short stroking Raptors.
What would be a better setup though 2 Raptor 300's short stroked 50% in Raid-0 or 4, 64 GB Solid state drives in Raid 0, sommething similar of the patriot variety so that pricing is similar.
Do you really need to RAID the SSDs? How much performance are you looking for. I'd think that RAIDed SSDs would be faster, zero seek times and RAID transfer speeds would be hard to beat.
Well I was thinking to raid them just for the hell of it. if I would be better off raiding 2 larger SSDs than 4 that would be an option as well. Why not raid them for the OS drive? is there more risk in raiding 4 SSD's or 2 VR's?
Always RAID. A single SSD with get smoked by RAIDed Velociraptors in reads and writes.
RAIDed (quality) SSDs will smoke RAIDed Velociraptors.
Well I'm thinking of SSD's that would cost about the same as stroked Velociraptors, I need at least 150GB of OS / Application space. Need some recomendations as far as SSD's go if they are really faster than similarly priced stroked raptors.
Wait for the OCZ Vertex ssd,200 reads and 160 writes.
Well, if you are going to be raiding the SSD's anyway, then the controller will be the limiting factor on the total throughput or the array. You can get by running SSDs that have a slower read and write speeds. With 4 of them raided, read speed will easily max out most controllers.
I am actually having the same question myself right now. My current mobo does not have onboard raid. Do I buy a stand alone controller, get a new mobo with Intel Matrix, Vraptors, or SSDs. Oh, decisions, decisions.
Don
