Guarana [BAWLS]
- Oct 3, 2001
So last year I built a new HTPC for myself, and... well... made a couple mistakes.
CPU AMD FX-8230E w 16GB RAM
Video: GTX950 2GB
So, currently it outputs 4K desktop resolution (because GTX 900's do that)
But it won't do 4K in any applications, because hard encoding.
Possible Upgrades:
i3 7300 + Board + 8GB RAM = ~275
This would keep the GTX950, and it would add 4K Hardware decoding to the CPU
Upgrade 2:
950 --> GTX 1050TI = 165 (and in stock at microcenter) - and the 10XX with 3GB+ will hardware decode 4K.
Which is the better route do you suspect?
(Or do I hold off, and see what happens with new video cards and CPUs that are coming out this quarter)
Video: GTX950 2GB
Possible Upgrades:
Upgrade 2:
