DarkenReaper57
- Oct 2, 2003
Hello all,
A while back I ordered some 7/16" ID Masterkleer tubing from Jab-tech.com. To my amazement, it was very clear. In the past I bought it from usplastics, and it was slightly opaque. About 2 months later, I bought some more Masterkleer from Jab-tech, but this time it had the same opaque, cloudy look as the tubing from usplastics.
Are there two different types of masterkleer?
Also, I read that you can "shine up" the tubing. What household materials can be used to do this? I think I read that alcohol + mineral oil works, but are there any other types of oil other than mineral oil that I could use as a substitute?
Thanks all, I just like the look of clear tubing, and I don't want to have to spring for tygon since I have perfectly good tubing sitting right here.
