2 side displays for a 3 screen eyefinity?
c3k
I've got the itch to add 2 more displays to my central 24" 1920x1200 display. I can't afford to add 2 more of the same size. I'd like to keep the verticle sizes the same. That means with this setup, [A][-24-][A], the "A" screens would have to be in portrait mode. What size displays would work?
(What screen has the same width as a 24" 1920x1200 screen has height?)
Thanks,
Ken
Well, just to tell you, eyefinity doesn't work like that. All display are going to need to display the same resolution and be in the same orientation. Now you can use those monitors in extended mode, but that still means playing most games on one screen or resulting to SoftTH.
I'd say it would be better to get 2 cheap 1080p panels for the sides and run all of them in landscape view and run a resolution of 5760x1080. But if you want to get the monitors with 1200 height, I'd go with dell 2007fp's they have 1600x1200 res. I don't know of any monitors that have a width of 1200.
