2 sats drives mirrored in xp pro (problems?)
SooperTool
just wondering if you ALWAYS have to install other drivers during the f6 phase if i want to set up raid 1 on 2 sata drives. i bought xp pro w/ sp2 and was wondering if maybe the drivers were already there with this release?
and just to clear this up, if its not when it says to hit f6 yada yada do i just insert a floppy with the raid drivers on it, and go(?)
at what point during install do i determine what type of raid setup i want?
tried searching, didnt see much. new to all this so thanks for any input
or maybe a reliable page with a raid faq, that woul dprobably help. googled, but no tsure if i can trust just any random hardware site
You don't specify the type of array during the XP install. You need to setup the type of array in the BIOS utility of the RAID controller. Once the array is configured, you can start the XP install and it will see one normal drive.
ok cool. that clears it up for me. this is the first time i built a system from the ground up with raid in mind. thanks man
