2 Quick Ram Questions
Pelori
What exactly is the difference between normal ram and "XMS" ram? I tried to look it up on google without much luck. My general assumption would be that it is faster // more efficient than normal ram (considering how much more expensive it is) - but I'd like to have that theory backed up if possible.
Also, would my:
ABIT AN8-V Socket 939 NVIDIA nForce4 ATX AMD
be able to support:
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINX2048-3200
without any conflict problems?
Thank you! =)
the only difference is that the corsair XMS is targeted towards enthusiasts... usually has tighter timings which will get you like 1-2% more performance :p
ahh, what about xms2?
another 1-2%?
and... can that motherboard handle xms or even xms2?
thanks!
another 1-2%?
thanks!
XMS2 is just XMS for DDR2.
Your board is for Socket 939 which is DDR1, so you can handle XMS if you'd like. XMS2 would require a socket AM2 processor board or an Intel board that used DDR2.
