2 questions on watercooling
havuk88
anyone know who makes the "lowest" low profile water blocks for the 7900gtx cards? trying to free up a pci slot for future upgrades... i would really like to go with the DD NV-78 SLI setup
also will watercooling the chipset allow me to run my A8N32 inverted in a lian li V2000 case without heat issues that come from running a board with heatpipe inverted?
The AquaComputer blocks look pretty thin, definitely not as thick as DangerDen's NV78.
1. Aqua Computer or EK will work from personal experience.
2. Yes, but you will have to buy a SLI chipset block for the NB. The heatpipe does not
work effectively inverted.
theseeker said:
You do not see many reviews on Aston-Martins either.
That's because you don't see many Aston-Martins on 7900GTXs.
The mounting kit is very expensive.
