Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
That pump is a monster, I would not be worried unless you want to throw on another GTX and NB/SB/Mosfet blocks. Even then I think you would want to split the loop for temps not pump power.
Tom128: How should I split the loop? Do you mean split the loop with what I have now, or split it only if I add the NB, SB, Mosfet blocks? Thanks in advance for all the input!
I think you'll be ok with 1 pump, but the others are correct, if you plan to add more to that loop, you are going to want to split it into 2 loops, or put 2 pumps on it. As it exists though, I think you'll be ok.
