It seems as though there are two schools of thought on the question of "which PSU should power each riser?" I spent a few hours researching multiple forums and posts, both here and on other mining forums. The advice being given is not consistent and seems to fall within one of two completely different approaches. I am not knocking anyone who has given advice on this topic -- I am just confused as to which is the right answer. The reality is that both approaches likely work for some people, else there wouldn't be such a divide. For reference, here are a few examples where it's clear there isn't a consensus in the thread:
https://litecointalk.org/index.php?topic=6171.0
https://litecointalk.org/index.php?topic=14758.0
As an additional question, also hearing mixed messages on whether or not the USB risers are safer because there is supposedly no power connection at the PCI-e point and "it's just a data connection to the motherboard" and the molex handles 100% of the power affiliation. I don't know if this is true or not, and how it might affect the overall answer of wiring approach.
I bricked two motherboards last night because I either screwed up, or had faulty equipment. I'm still not sure. But I want to get it right when I try again. A picture paints a thousand words, so I would love your comments and expertise as it relates to these scenarios. I'm fairly new to HF and have been impressed with the knowledge here - don't let me down
Note: my situation is a bit unique because I'm introducing a 2nd motherboard to take advantage of an additional PCI-e slot (just onboard right now, and can potentially add an additional riser to this 2nd mobo). I would think removing mobo2 and the 6950 directly seated on mobo2 from the equation would get you to a more familiar scenario but I wouldn't think it would change the answer, or would it?
Thank you in advance for all your help and responses.
