Jiggaman2576
- Oct 27, 2004
I've been doing some reading and I just want to make sure I can do this. I have 9 hard drives in my PC, plus all the other junk in my signature. I just got an X1900XT which I flashed to an XTX and I have been overclocking the crap out of it. I've run into a wall though. Turns out running 9 hard drives, an overclocked AMD X2 3800 at 5000 levels (2.6ghz) with 2GB of ram, an X1300 (3 monitor setup now) and a sound card is kinda taxing on my OCZ 600 watt powerstream. I've just ordered the 700 watt and I'll have it Monday. I figured why not use both together to make it easier on each.
I have 2 power supplies right now but I only run fans/lights on the 2nd PSU, oh and the water pump. It doesn't have much of a load on it. What I want to know is, if I replace that with the 600 watter and run all my hard drives/DVD-R plus all the fans and lights on that power supply, and run just my motherboard and all the things on it with the new power supply, would I risk frying anything? The theory behind this is that if the hard drives are getting power from one power supply, and the signals from it are from another power supply, and there is a differential between them. One power supply would try to charge the other power supply. That is not a good scenerio to have. However if the data signals do not care about that since they are low voltage I would assume, it shouldn't be a big deal right? I planned on having my 2nd PSU on a switch instead of relayed into the first one. This way when I have to do mega rebooting shut downs my hard drives are spared the cycling of power. I also have a crapload of white cathodes in my PC that I use for work lights when I want to mess with something or change out a card. Its pretty handy to be able to leave the 2nd power supply on to do that with the first one turned off on the back.
So, to sum it all up, is this safe? Will it work without harming anything? I plan to find out Monday but I'd like a heads up first if someone here has any ideas about it. Thanks in advance guys.
Jigga
Jigga
