fiberoptik
- Mar 1, 2005
Anyone out there with an Evga 6800gt?? Are there really 2 power hookups? Do they both need to be hooked in or is one a pass through?
GTPoompt said:Is that AGP? The agp bridge doesn't give as much power as PCI-E, so thats why 2 are needed
fiberoptik said:Ah.. ok so the second molex is just a passthrough.. The manual wasn't very clear.. thanks guys. And yes this is the pci version.
Brent_Justice said:if it is a passthrough one would be female, but if they are both male, then plug two connectors from your psu into it, it can be from the same line
Solutions said:My 2 pennies:
I think the lack of higher OC's when in SLI mode is related to the communication needed between the cards. I'm not positive on that but it is my guess. I am using a Enermax 650W (peak) PSU and I think that should provide more than enough power.... its even got the dual PCIE power plugs. I'm still tweaking but so far I seem to be limited to 435/1175 (IIRC) when in SLI mode. I think in non-SLI mode it would reach 445/1200.
