i replaced my PSU a week ago and wanted to use the old fan in the PSU as an extra case fan, but the fan is only 2 pinned, red and black. is there a way so that i can use it without a connector?
i was thinking of snipping the pin off, shave the insulation, then do the same to a 4 pin molex and connect the wires.
ALSO one thing to ask.. can i use an ATX PSU in a micro atx case? i tried it and it fit in the slot perfectly, but insteading of holding it up with 4 screws, it uses 2, but i have yet to turn the PC on and test it. would it work?
