2 PCI-E Cards, 3 Monitors, One Resolution?
Fee
I have a question about a setup i want to make in the next couple of months for Flight Simulator X. I plan to make a C2D system with 2 8600 Ultras and 3 LCDs. Right now im playing FSX on an amd 64 system with a 6800GT and 2 LCDs. I use the nView Desktop Manager's Horizontal Span to merge the 2 LCDs together and play FSX at a WS Resolution. I was wondering if i could do the same with 2 video cards (non SLI of course) using Desktop Manager's Horizontal Span to merge the 2 8600s together and have WS resolution on the 3 LCDs For FSX. Is this possible? I tried google and couldnt find any real info about it, and i no knowage of a system with multipal GPUs. Any thoughts on the idea would be appreciated. Thanks
you can,but i think you cant run in Sli mode though. Its best if you use it with 2 only; then you can use SLI. Also making it widescreen on 2 monitors is a bad idea unless the casing around the monitor isnt to thick in the center.
