the lone gunman
- Oct 30, 2005
ok i ran the windows xp install and when it came to the "select a partition" to install winxp on i selected the option to create a new partition (this is on my maxtor 80GB) so i created a 40GB partition to install XP .... fine no problems. installed got to a desktop.
then i put in my win2k cd and started the intall..... it went through its prossess of checking hardware ect... then gave me the option of installing win2k on the unallicated disk space (the extra 40BG) on the 80GB maxtor so i click enter.
however my problem is whilst intalling i noticed that win2k has the drive letter E: as apposed to C: which is what exspected? i know winxp is on C: but i assume that because the is a NEW partition win2k would be installed on its own area so when i boot my computer the bios will ask me wich OS i want to load? (because both will be on a C: drive?)
i am actualy still going through the install of 2k right now so any advice about weather i have fucked up the install i.e a dual boot configuration then please let me know ASAP =]
