Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Ive already got an FX 5200 ultra in a machine at work running two screens. Can I install a second nvidia card and run 4 screens? If so, will I still be able to run 4 individual desktops (no cloning or spanning).
you should be able to pop in however many pci video cards as you want.
depending on how the nvidia display driver treats cloning and such, you should
be able to get what you want out of it. there are other monitor programs
that will do other things as well ( ultramon )
I dont use dual monitor here anymore, so it's been a while.
someone will know.
