2 Noob processor questions
deadman_uk
1) What's the difference between a processor and a CPU
2) If I have a dual core processor @ 2.6GHz, is the true speed 2.6GHz or 5.2GHz? and why is this the case? (I am assuming each core runs at 2.6GHz)
processor can mean different things. ppu (physics processing unit) cpu (central processing unit) gpu (graphics processing unit). the cpu is just the primary control device of the entire computer.
yes a dual core processor has two processors running at the same speed. normally only one processor runs but in other cases when a game requires more processing power the other processor takes some of the load off of the other. so you could have one core running %100 and the other one at %50 if you are playing a demanding game like supcom. hope that helps
You do not add the two core speeds together. They work independently of each other. Think of it like having two CPUs in your system stacked on top of each other. Generally, if you run a program like an antivirus, and then run a CD burning program, you will often find that each program will run on its own CPU.
I hate the bastards on ebay that say it's twice as fast as it really is. But I guess there will always be a jerk out there trying to scam someone.:rolleyes:
While it definitely isn't twice as fast as a single CPU equivalent, both my friend and I saw big improvements over the single core versions of our CPUs, for both gaming and general usage. Drivers have really improved on their abilities to balance the load between CPUs.
While I wouldn't say twice as fast, I would still highly recommend that anyone buying a CPU these days seriously considers buying a dual core.
