jay2472000
- Oct 6, 2008
Ok so me and my neighbor are trying to come up with a way we can "share" a seedbox. I have the crappy cable internet ( but with 3 kids, Im always broke) and he has pretty good DSL (thats truly unlimited, unlike my cable) What we would like to do is have one box both networks can use, sort of a shared folder. The deal is, if I admin the box. His IP ranges are in the 192.168.1.1 range and so are mine. So basically, what I am trying to do is have a box on both networks, BUT all downloading has to done off one network.
I was playing with this before, using a wired 10.0.0.XX and a wireless 192.168.1.XXX address and if I remember correctly if I manually set the 10.0.0.XX address to use 192.168.1.1 as the default gateway it wrkd. ( and I may very well be remembering wrong as I only did it once and it was a long time ago.)
I believe the issue is that were both using the 192.168.1.XXXX range where BOTH of our gateways are at 192.168.1.1. So for this to work Ill have to go to the 10.0.0.XX range or some other, correct?
Any and all help is appreciated.
