I recently bought a monoprice 27 ips-zero-g 1440p monitor. It works great. I tried plugging in my old ASUS 1080p monitor in the second DVI slot to use two monitors at once. Everytime I plug it in, my main display goes black. It does not turn off or say "no display" it simply turns black. Furthermore, if I try plugging my Monoprice or my Asus back in to EITHER DVI, it does not return a display. I've tried using a dvi-d single with the asus and a dvi-i dual. Neither work. My Monoprice is hooked up with a dvi-d dual. I don't have two dvi-d dual cords to test that.
I have also gone into windows options and turned my Monoprice down to 1080p instead of 1440p just incase that was the issue. Still happens. I tried looking through Nvidia Control Panel but there is no options that look like it would "turn on" multiple displays.
I feel this issue has to be related to either DVI-D Dual + any other cord = 1 display
My operating system is Windows 7 64-bit with all updates. My Geforce drivers are fully updated. My bios settings are set at "Use discrete graphics" instead of onboard.
